New brake same old noise
Old Apr 3, 2014 | 07:44 PM
tentoesjoe's Avatar
Default New brake same old noise
Hi I just replaced my front rotors, pads, and calipers as well as my wheel bearings and it sounds like my pads are rubbing the rotor on the passenger. Unfortunately thats what led me to replace my brakes in the first place. Any ideas on how to resolve it?
Old Apr 3, 2014 | 09:45 PM
geek_IM's Avatar
Hmm did you buy mintex pads perhaps? I put cheapie pads in my fronts and they made such a racquet of clicks, rubbing noise and rattling that I finally stepped up to the plate and bought the green EBC pads and problem solved. No more noise.
Old Apr 3, 2014 | 10:24 PM
abran's Avatar
Sorry for the late advice, but did you do the defender upgrade on the rotors and calipers?
X2 on the green EBC.
Old Apr 4, 2014 | 05:11 AM
tentoesjoe's Avatar
no I bought the brake rebuilding kit from AB
Old Apr 4, 2014 | 05:56 AM
tentoesjoe's Avatar
It came with bearmach rotors and delphi pads.
Old Apr 4, 2014 | 07:18 AM
abran's Avatar
Never tried it. AB is pretty good with customer service, call them and see if they have an answer.
Old Apr 5, 2014 | 07:21 PM
tentoesjoe's Avatar
Well I pulled the front passenger hub back off and tapped the race ring a little further in and then put everything back together and lo and behold it works with no noise. I guess the bearing was a little off so the caliper wasnt even on the rotor.
texasdisco1
May 9, 2013 06:28 PM
bothomasmusic
Jun 17, 2011 11:52 AM
96SILVERDISCO
Sep 28, 2009 08:20 AM
cplthomas
Apr 29, 2008 08:43 AM
VinDiesel
Off Topic
Oct 10, 2005 06:42 PM
