New Brown Brake Fluid!
Old Feb 15, 2012 | 08:25 PM
Josh.0's Avatar
Default New Brown Brake Fluid!
Check this out...good thing the master cylinder went out. I started to bleed the system and this came out. I'm flushing the whole system now...
Old Feb 15, 2012 | 09:14 PM
Banzai Jimmy's Avatar
That's why the system should be flushed every couple of years. I've had it in the back of my mind to flush my system very soon - been too long.
Old Feb 15, 2012 | 09:32 PM
reboot's Avatar
Is that the original fluid?
Old Feb 16, 2012 | 08:28 AM
Josh.0's Avatar
Que??
Old Feb 16, 2012 | 09:25 AM
jafir's Avatar
Originally Posted by Josh.0
Que??
spam.
Old Feb 16, 2012 | 09:28 AM
EricTyrrell's Avatar
mmm take a swig.
Old Feb 16, 2012 | 09:56 AM
Danny Lee 97 Disco's Avatar
Could be why the master cylinder went bad as well. You know it starts out clear, the darker it is the more particulates there are in suspension. Wonder what density that fluid is? Will light even pass thru it?
Old Feb 16, 2012 | 10:23 AM
XCELLER8's Avatar
Originally Posted by EricTyrrell
mmm take a swig.
I wouldn't dare drink it straight, maybe with a little JD though..
Old Feb 16, 2012 | 11:29 AM
Josh.0's Avatar
Yes I know it's clear. One of the seals on the bottom of the container started leaking. Good thing too... There were chunks of crap in the fluid. It's all clear now. Light could pass through it but not much. I'd equate it to the transparency of nyquil.
The fluid in the master cylinder was clear...so I guess all that must have been in the lines for a while...if you haven't completely bled the system in a while you might want to think about it!
Old Feb 16, 2012 | 03:07 PM
That';s why they recommend using a turkey baster to suck it out of the reservoir and bleed each line until it runs clear. That dark has a lot of junk in suspension. That could play hell on small openings.
Paul Grant
Jul 11, 2013 03:53 PM
doxster22
May 17, 2013 03:03 PM
wrongway1
Jul 21, 2012 03:27 PM
ColoDisco
Jun 8, 2012 12:15 PM
2002 freebie se
Freelander
Mar 29, 2011 10:08 PM
