New member come back
Old May 29, 2014 | 12:33 PM
GLOCK3462's Avatar
Default New member come back
good morning everyone
my name is Hernan i am from Ecuador, rover lover all my life, now i got the chance to buy a 1993 discovery 100, blue with blue interiors stock
first of all thanks for letting me be a part of this forum
now let me tell you my problem
first what i have done to my disco and the engine
v8 3.5l
1993 land rover discovery
model 100
4 door
manual transmition
petrol engine
ecu amr3242 replaced
replaced sparkplugs and wires
baterry replaced
voltage on running engine 15volts
has been overheated but overall no visible problems or faults
no codes on the scan
recently replaced gas pump
changed all the fusibles
and cleaned the stepper motor the maf and the water temperature sensor, with a sand paper (dont know if i damaged )
now, it runs perfect when he wants, normally it starts good after 1 turn
nowadays, when i am running it just wont let me acceleratte, no throttle at all and when i stop it it turns off, then i have a lot of problems starting him
after 5 minutes it starts ok
full or with low petrol on, always on a hot engine
i have changed some ecu relays and fuel pump relay also
another ting that happeneds is that when i turn it on and run like 1 minute for a part of a second it stops turns on a light on the dash like a "!" and then it goes normal, and when he wants it just fails starts to run rich smelss like gas a lot, and is very low on power, with counter explosions
happy to know if you can guide me a little i;ve managed to know my disco with the problems but i dont know what to do
greetings
Old Jun 3, 2014 | 11:42 AM
GLOCK3462's Avatar
Anyone
Old Jun 3, 2014 | 04:38 PM
You can also use carb cleaner spray for the stepper motor. You vehicle may have an ignition module near the distributor, these can become heat sensitive and cause problems.. A relocation kit is available.
Old Jun 4, 2014 | 09:59 AM
GLOCK3462's Avatar
thanks
i will do this to get a better ignition, but maybe some guess on the other trouble?
it just fails on a bad road on pavement goes perfect
fienneone
May 21, 2015 11:22 PM
Discovery_Scott
Jan 8, 2012 11:42 PM
Cosmic88
Mar 9, 2011 06:53 AM
Mr. Krisztian
Jan 22, 2008 12:58 AM
