New Motor Choices
Old Apr 6, 2012 | 09:13 AM
BFRieck's Avatar
4th Gear
Default New Motor Choices
I've found a manual tranny '95 Disco I for my Series hybrid project (I plan to put a Series IIa 88 body on the Disco I rolling chassis). The price of the Disco I is good for what it is, but it appears the motor is a goner as it probably needs a block to cure a water leak that replacing the head gasket didn't take care of. I may use the Disco for a while before I remove the body and start the hybrid build. Either way, I need a new motor. I'd like to improve the miserable gas mileage that apparently comes with the V-8 so am considering a diesel. Everything I've read indicates that the 200tdi is probably the way to go, simpler but just about as much power as a 300tdi. I've read, also, that the 200 is pretty much a bolt in on a Series chassis, especially if the turbo is re-plumbed so it won't foul the frame or the motor is de-turbo'ed. I understand the 300 is bigger and therefore not as easily fit. What are the forum's thoughts on this? Also, should I be considering any other diesels or gas motors, even non-LR?
Old Apr 6, 2012 | 11:41 AM
Danny Lee 97 Disco's Avatar
Is the 200 even a Turbo?
Old Apr 6, 2012 | 04:17 PM
BFRieck's Avatar
4th Gear
I thought it came either way, but it may be that they are all turbos, but the turbo can be removed.
Old Apr 18, 2012 | 12:49 AM
Beamer1's Avatar
Would there be smog compliance issues? A Tdi would be awesome...
tasr12
Dec 17, 2009 01:17 PM
Galaxie_406
Jan 5, 2009 07:03 PM
phidelt583
Dec 8, 2008 12:36 AM
stefan
Jul 8, 2005 08:46 PM
