new p0300 code after plug change
Old May 22, 2018 | 10:54 AM
mware18's Avatar
Default new p0300 code after plug change
96 discovery se with 170k. change plugs over the weekend and found multiple loose plugs and really bad gaps.
Changed all plugs with champion copper with gap of .030.
This morning had really bad miss and felt like it was running on 5-6 cylinders when trying to accelerate. Idles smooth but does not like to climb hills.
Check codes and got p0300.
Ordered wires this am. What else should I check?
Old May 22, 2018 | 11:32 AM
fishEH's Avatar
I'd start by gapping your plugs correctly. The RAVE manual recommends .033" to .038". I usually gap mine around .040"; bigger spark but shorter plug life.
Old May 22, 2018 | 11:50 AM
mware18's Avatar
I'll try that this afternoon.
Thanks!
Old May 23, 2018 | 10:43 AM
mware18's Avatar
checked under hood last night in the dark and found #3 wire arcing at the coil pack.
I ordered new wires yesterday and hope they will be in by the weekend to replace.
Hopefully this cures the problem.
Thanks!
wynhd
Apr 1, 2018 07:35 PM
Scott Weiland
Oct 16, 2013 01:15 PM
collin Barrows
Aug 28, 2011 07:13 AM
ljdiscovery
Jan 12, 2009 04:05 PM
