new problem...brake light
my brake light was out(right side) so i went to change the bulb and after replacing it, it still did not work. yes i got the two prong bulb. the nighttime driving lights that comeon when you put your lights on work but when i press the brake it does not get brighter so i do not think its a faulty bulb. Also it fit perfectly so im sure i got the right size but can somebody tell me the correct bulb size so i can double check? thank you
Here's what happened to me: the bulb holder had overheated, the metal contacts sunk into the plastic and there wasn't contact between the holder and the light assembly.
After much modifications, the best solution was to solder wires from the light assembly to the bulb holder. I haven't thought of it for 5 years.
I hope this is not the solution you need but if it helps you go ahead and don't burn your finger soldering.
SD
I had a problem with my headlight wiring being corroded. So instead of trying to fix the crap that was there I took the headlight assembly down to NAPA and matched up a whole socket from another vehicle (can't remember which at the moment) that just pops into the same size hole that the old one fit into, came home, cut the wires on the old and soldered and heat shrunk it. Now I can buy a regular old cheap bulb from Wal-Mart, no worries. That's what I would do to the rear if I were you. Anything electrical that I can rewire and get rid of LR stuff the better off I am.
Locate the brake light track on the light cluster. Look at it closely near the hole where the bulb goes in and you should see the metal track sunk into the plastic just a little too much. Slip a tooth pick between the metal and the plastic housing to lift the metal up.
reassemble the bulb and holder into the cluster and test.
If this works, replace the tooth pick with a piece of hard plastic (the insulator of crimp connectors is ok), the wook can catch fire and metal will just sink into the plastic again.
I should have taken pictures when I did mine.
SD
BearCatRover
12-11-2013 04:03 PM
rreinholt
10-10-2013 08:47 AM
bigbris1
07-03-2007 08:02 PM
