New Problems Arise
Old Oct 21, 2012 | 01:28 PM
96discokid's Avatar
Default New Problems Arise
Ok so today my 1996 Disco took a very long time to start and then later on died at a stop light but started right up and was fine, I was thinking spark plugs. Also whenever the truck warms up after 30 or so minutes of driving the lifters stop tapping very loudly at idle and goes away at about 1200 RPM, I was told from a neighborhood mechanic that this could be from running too thin oil, 10W40 or I might need a new exhaust manifold gasket. Any help would be great!
Old Oct 21, 2012 | 02:18 PM
marjac's Avatar
Check out the thread on the general maintence page regarding oil and oil filters. SHELL Rotella T 15w40 seems like everyone's choice. I know it was an instant improvement in my 96. Clean the out Idle air sensor, and SeaFoam clean the throatal body and that should help. These are all easy and
quick. Less than 50.00 . Great how toss on the general maintenance folder!
Old Oct 21, 2012 | 06:30 PM
X2 on Rotella and good jumbo filter. See the tech area for a write up. If your 96 has an OBDII port might also consider attaching a scanner to see real temperature. If running hot, oil can be thinned out. Gauges are not very accurate, as pix shows. 180F thermosat works great in my D1.
Old Oct 22, 2012 | 06:29 AM
96discokid's Avatar
Ok thanks guys ill work on it and cgeck tge write ups today.
Old Oct 22, 2012 | 04:00 PM
96discokid's Avatar
So I looked at today, temp was fine stayed under half at all times but was told I had a collapsing upper radiator hose. I was told it's collapsing when the truck hears up so this should be an easy fix.
RicketyTick
Jul 2, 2014 11:46 PM
Frank4
Mar 21, 2014 05:21 AM
formel3
Jun 13, 2013 12:33 AM
Hyakku
Jan 9, 2011 11:32 AM
Si
Jan 2, 2005 11:36 AM
