New proud owner
Old Jul 20, 2013 | 12:41 AM
Xjfletchx's Avatar
3rd Gear
Default New proud owner
I just purchased a 1994 Discovery for $1200. 164000 miles. The previous owner had new heads installed less than a year ago. Still under mechanics warranty. It does have its problems though. It needs a new expansion tank, two of the five doors are hard to open and the CDL only has high and low and will not go into lock. I've done searches and found most of the articles i need. I look forward to learning more on this site. I'm already in love with this SUV. I took it up a hill this afternoon in low unlocked gear that my buddy's 4x4 Nissan couldn't go up.
Old Jul 20, 2013 | 12:57 AM
Xjfletchx's Avatar
3rd Gear
Sorry for posting this here. I just found the "new member" forum.
Old Jul 20, 2013 | 08:31 PM
Welcome. Glad to have you here. The CDL will "freeze up" from lack of use. I was able to remove part of the stuff on the console, and snake a straw down along the shift lever under all the material, and soak it with PB Blaster, and mine came loose. The RAVE is the factory shop manual, you'll want to download that. Heads will last longer if you don't overheat, the factory gauge is not real accurate. On my 97 it read about 55%, when it is 235F. I switched to a 180F stat.
Old Jul 22, 2013 | 04:11 PM
Xjfletchx's Avatar
3rd Gear
Thanks buzz. I've read ur posts on the cooling system. They were great. I was unsuccessful in freeing up the shifter. I will be replacing it I'm sure. It's a 94 and I believe it's never been in diff lock.
Jacks07
May 28, 2010 01:09 PM
jbassman
LR2
Sep 11, 2008 10:35 PM
lagwagon
May 12, 2008 04:05 PM
Scanner
Feb 14, 2008 03:00 PM
tdiddy
Feb 11, 2006 02:21 AM
