New radiator now trans cooling line leaking 98 Disco I
Old Apr 20, 2015 | 08:25 AM
Jagfixer's Avatar
When I replaced my radiator, I had to by new line joiners between new radiator and old lines as the new radiator had different threads.
Old Apr 22, 2015 | 10:07 AM
pbrown2074's Avatar
Did not have that problem with wring threads. Still waiting on my new lines to come in but have another question. Is it transmission fluid that goes through all these lines including the ones to the external cooler?
Thanks,
Paul
1998 Disco I
1999 Disco II
Old Apr 22, 2015 | 11:05 AM
OverRover's Avatar
"Is it transmission fluid that goes through all these lines including the ones to the external cooler?"
YES, it's one big closed loop.
If all you are doing is replacing the lines and fluid(At filter is more involved see link), then drain the fluild, replace lines, and refill.
This link will help, have a look> https://landroverforums.com/forum/di...-filter-34270/
Pic 2: drain plug removed. Pic 3: Look on the LEFT side and you will see the 2 lines that mount to the trans. 1 line is above the shift linkage and the other is in front of the AT pan(pic 4 gives a better view).
Now go wait for the UPS truck.
NoogaRover
Apr 3, 2015 06:10 PM
Hawk99
Mar 3, 2015 12:13 PM
innzane
Sep 23, 2012 01:43 AM
JerrodSteph
Jun 12, 2011 06:04 PM
twmj1953
Aug 8, 2010 06:53 AM
