New, what do i look for?
Old Dec 27, 2020 | 12:28 PM
John Carlson's Avatar
Default John Carlson Disco 1 journey
I plan to take a lot of pictures and ask advice/opinions from this group. As you can see from the pics below, the oil looks good, the spark plugs were up in the .04 range, so the new one I put in will be gapped better. Other issue i am having is getting the key out of the ignition, what exactly needs to be done to release the solenoid? I have it in park, does the hood need to be down? Transfer case in gear?
Old Dec 28, 2020 | 10:57 AM
jimvw57's Avatar
key needs to be pushed in and then slides out. I have gotten used to it. There is a pin that keeps from removing it if you are not in park. Plugs don't look too bad.
looks like you need those plastic parts on the headlight
I am up in Red Wing if that helps..
Old Dec 28, 2020 | 11:51 AM
WaltNYC's Avatar
The keys get stuck in the ignition due to worn tumblers in the ignition barrel.
https://landroverforums.com/forum/di...ock-fix-35422/
Old Dec 28, 2020 | 12:49 PM
I'm down in Spring Valley, moving on to the Valve Cover Gaskets now.
Old Dec 29, 2020 | 10:53 AM
WaltNYC's Avatar
by the way, if you need/want any of the workshop manuals, they can be found in the google drive link in my signature. Have at it.
Old Jan 2, 2021 | 06:12 PM
Default Yep!! Needs valve cover gaskets!!
Well, im going to put the new gaskets in with some permetex. Then i guess an engine flush is in order. Any reason not to engine flush one of these?
also let us know if you need help[/QUOTE]
Old Jan 2, 2021 | 09:47 PM
Default Bracket
How do you move this bracket to get off the passenger side cover?
Old Jan 2, 2021 | 11:22 PM
Toran's Avatar
Give it another look over, there should be a screw holding it in place.
Old Jan 3, 2021 | 05:20 PM
I ended up bending the tab up. Found that info on a youtube video. next question, is there no gasket between the intake and intake manifold? I got a plenum gasket at orielly's, I just don't see where it goes.
Old Jan 3, 2021 | 06:50 PM
Toran's Avatar
Are you talking about this part:
Intake Manifold Gasket Kit, New Style, For Land Rover Defender 90 And 110, Discovery I, Range Rover P38 And Range Rover Classic (See Fitment Years)
Item: 9218A
Fits
  • Discovery I | 94 - 99
  • Range Rover Classic | 87 - 95
  • Range Rover 4.0 (P38) | 95 - 99 | GEMS MOTOR/SINGLE EXHAUST
  • Range Rover 4.6 (P38) | 95 - 99 | GEMS MOTOR/SINGLE EXHAUST
  • Defender 90 | 94 - 97
  • Defender 110 | 93
