No Brake fluid in Brake Line
97 Disco... Brakes acting funny today and went to the floor. So, I sucked the old fluid out of the brake reservoir with a syringe. The fluid was definitely not clear. It was very cloudy. I had a friend pump the brakes as I started on the rear right tire and bled the brakes (After i filled the reservoir with new DOT 4 fluid). I went around to all 4 tires but got to the drivers side front and it bled a few times then nothing. No fluid would come out. I took the brake line off from the ABS module to the brake caliper and no fluid came out.
What next???
Thank you
What next???
Thank you
JerrodSteph
Jun 12, 2011 06:04 PM
LRScott
Mar 4, 2009 08:39 AM
