No gauge or other interior lights
Old Apr 7, 2011 | 08:26 PM
Danny Lee 97 Disco's Avatar
That means the switch is getting worse.
With mine, if I grabbed it with pliers and twisted it really hard, it worked, until you turned them off.
If you want all of the instument lights and headlight,taillights to function properly, change the damn headlight switch.
HERE'S YOUR SIGN.
Old Apr 7, 2011 | 08:27 PM
Garrett's Avatar
:rofl Calm down sir.
The right side lights (except headlight and directionals) don't work either I have just noticed.
Old Apr 7, 2011 | 08:29 PM
OK, suit yourself. Keep on using it until it totally goes out.
Old Apr 7, 2011 | 08:30 PM
Garrett's Avatar
As said. Calm down. I'm well aware of what the issue is now. I'm just stating that it is getting worse. I'm gonna hit the bone yard tomorrow where there are a few D1s and grab the switch.
I don't see in the RAVE how to remove that switch I'm new.
Old Apr 7, 2011 | 08:57 PM
To replace the head light switch.
Turn steering wheel all the way to one side, remove key and lock the wheel.
Remove the steering column cover.
Remove 2 screws holding switch in place.
Remove switch.
Install is reverse of removal.
Old Apr 7, 2011 | 08:58 PM
Garrett's Avatar
Thank you!
Old Apr 8, 2011 | 12:36 AM
FERNO's Avatar
8th Gear
So fuse# 18 is not borked then
Old May 20, 2011 | 01:50 PM
Garrett's Avatar
Bumping an old thread. Finally put a used headlight switch in. Highbeams work fine now. But the right side lights and presumably in the interior lights are still dead (I say presumably because it's 3oclock and sunny here)
What else could it be? Which fuse should I check?
nehi1429
Mar 14, 2015 10:33 AM
outdoor7or24
Sep 6, 2012 10:32 PM
Mountain Goat
May 27, 2011 12:29 PM
USMC_Denver
May 8, 2009 12:41 PM
