No heat unless revving.
Old Dec 16, 2017 | 06:41 PM
chewy4000's Avatar
7th Gear
Default No heat unless revving.
Coolant it topped off, I think bleed correctly, new thermostat.
Heat only comes on a little while raising revs a little.
If truck is idling no heat at all, rev 60 sec a warmer air comes out.
WHAT AM I MISSING?
thnx in advance
Raul
97 Disco1 SE7
Old Dec 16, 2017 | 06:54 PM
OverRover's Avatar
Sounds like there is still air in the system. Bleed it again.
Old Dec 16, 2017 | 08:29 PM
ihscouts's Avatar
Either that or belts misrouted...... not uncommon for the DIY crowd.
Old Dec 16, 2017 | 08:36 PM
OverRover's Avatar
It's certainly possible.
Old Dec 16, 2017 | 08:37 PM
ihscouts's Avatar
The impeller works better in the opposite direction.
Old Dec 20, 2017 | 11:43 AM
hrhoward's Avatar
Sharpie on the support
Old Dec 20, 2017 | 12:22 PM
WaltNYC's Avatar
Sounds like air indeed.
Run the RPM up to 2700 for about 40 seconds with the heat on full blast.
Old Dec 21, 2017 | 11:43 AM
chewy4000's Avatar
7th Gear
OK, after 3 or 4 times of topping up Reservoir while cold, then driving it. Seems to be reaching the heater core now.
pottzie
Jul 25, 2012 09:24 PM
97DiscoCincy
Mar 12, 2011 04:59 AM
alias_J
Jan 28, 2011 02:36 PM
josemex
Dec 20, 2009 08:38 PM
dustondo
Apr 17, 2008 09:28 AM
