No spark from coil
Old Feb 27, 2021 | 03:39 PM
Tommyblack97's Avatar
Default No spark from coil
Hey guys I have a 1995 discovery one 3.9l. I have no spark to any plugs and no spark from the coil. What are some test I can do to determine where the issue is? Thanks
Old Feb 27, 2021 | 03:44 PM
Best4x4's Avatar
Do you have 12v at the coil with the key on? If so then the next thing to check would be the ignition amplifier, followed by the rotor.
Old Feb 27, 2021 | 03:55 PM
across the coil I have nothing. From positive side of coil to ground strap I have 12 volts with the key on
Old Feb 27, 2021 | 05:00 PM
Ok I performed all 7 tests on the rave manual and it passed with flying colors just now spark still. Bit the bullet and sacrificed my meter to check the voltage coming out of cable going to distributor. Only got 12volts. Where it should be like 30,000 correct? I’m thinking bad coil?
Don Neville
Mar 9, 2022 10:20 AM
Matt Couleur
Sep 22, 2019 03:51 PM
Dinknose
Feb 16, 2018 11:40 PM
frankh
Apr 12, 2017 09:52 PM
alpinab7
Aug 2, 2006 11:36 PM
