no start
Old Mar 1, 2025 | 06:55 PM
JohnZo's Avatar
So maybe it is not getting enough fuel if it only sputters. I would try to measure fuel pressure, then replace the fuel pump if the pressure is low.
Workshop manual shows checking pressure at the fuel filter (behind RR tire). Good opportunity to replace the fuel filter. I might try to measure by disconnecting the fuel rail supply tube. Newer models have a schrader valve built in to the fuel rail that makes it easy to check pressure. I installed a fuel rail from a '96 onto my '94 for that reason.
Cap-n-Cray
Aug 13, 2020 05:09 PM
Jshane420
Freelander
Apr 16, 2017 11:01 AM
Phant0m
May 20, 2013 12:58 AM
2000 Disco 2 SD7
Aug 20, 2008 12:37 PM
fazekas123
Jun 9, 2008 10:39 AM
