No Start- Crank Position Sensor?
Been reading that a no start (turns over but no fire) can also come from Crank Position Sensor. I got one on order. NOT CHEAP. 60ish buks.
Anyway.... mine appears to be magnetized. Least I think that is the CPS. The cap is Grey, The cap has metal shredding on it magnetized to it.
Sound normal? New one wont be here till Tues AM.
Similar location different sensor on d2 iirc
When you get the plug off can pull wires straight up from top to inspect
How do u know there is metal on the sensor if you have not pulled it?
does not make sense to me either, especially since material looks more aluminum than steel. Anyway it appears that some force such as magnification is so strong that this material it is held against the cover. Like metal flakes on a piece of paper held there by a magnet below it. Which again makes no sense......... Aluminum is not affected by magnets. Aluminum and static electricity ?
Crank Position Sensor is on order. Was suppose to be Tues. morning. It's Wed. night and it is still not in.
