Noise and heat isolator - trans and interior
Old May 25, 2013 | 09:45 AM
Optimusglen's Avatar
Default Noise and heat isolator - trans and interior
Hi guys, searching from head to toe to find a part number or any info on this piece. It would go between the transmission and the interior shifter trim to damped the noise and heat coming from outside and under the truck.
It's missing on my D1, and that paired with a hole in the shift boot means I can see the road if I look down there. It also means that once it's up to temp, hot air BLOWS out. No fun.
I looked through the Rave workshop manual and bodywork manual and didn't have any luck.
I've been Google image searching but only seeing the trans alone.
Any help is appreciated.
Old May 25, 2013 | 09:51 AM
Whoa, I think this is it. Does this look stock to you guys?
edit: yes I think this is it. Now I just need to find where to get one...
kylan1234
May 31, 2014 03:07 PM
jmason
Nov 17, 2013 06:39 AM
sclarkie
Aug 22, 2013 08:17 AM
ebg18t
Aug 19, 2013 11:54 AM
grandkodiak
May 13, 2012 05:29 PM
