Not a Ping but a Knock.
Old May 21, 2011 | 08:19 PM
adigerol77's Avatar
Default Not a Ping but a Knock.
So at low rpm from stop to light pedal, I can hear a very faint knock, seems to be coming from the drivers side, bottom of the engine, after about 20mph it goes away, prob due to other ambient noise but, wondering, cam wear? No rough idle, no smoke, exhaust leak maybe, cat?
Old May 21, 2011 | 08:24 PM
AuZZZie's Avatar
Exhaust leak would usually sound like more of a ping/ticking sound so I don't think that would be it.
What are you running for oil? My valve train lost a few dB after I switched to Rotella 15-40.
Old May 21, 2011 | 09:35 PM
adigerol77's Avatar
Yah that's the next thing on my list, dropping the oil pan and changing oil. I just got my new oil drain plug from AB, the existing one is rounded off.
I have been reading a few posts from Spike though when you switch from standard to synth or rotela you need to do a gradual intro? Can't remember exactly. Also the new gaskets soak up tons of oil. I'm over thinking I'm sure.
Old May 21, 2011 | 10:39 PM
Just pick one brand and type of oil and stick with it.
Yes the gaskets can soak up alot of oil until they get "used" to it, but once that is done you will be good to go as long as you stick with the same oil.
I use Rotella and thats what I recommend.
Old May 21, 2011 | 10:58 PM
adigerol77's Avatar
Thanks! And Bill Murry thanks you too.
Old May 22, 2011 | 08:59 AM
Its the Army, how bad could it be?
desmd99
Jun 24, 2014 11:01 AM
ngarover
May 4, 2013 09:18 AM
Racerx04
Nov 30, 2012 07:16 AM
calbuild
Oct 19, 2009 05:10 PM
Disco Fuego
Apr 28, 2009 11:56 PM
