Obd1 code reading
Old Jul 1, 2010 | 10:05 PM
tweakrover's Avatar
Default Obd1 code reading
I have a 94 which we all know has obd1, it has a digital display under the passenger seat for the 2 digit codes it uses. Is there any other info that can be gained from a scangauge tool that the codes won't tell me. I hear you obd2 guys always talking about engine temps and stuff, does obd1 carry that capability.
Old Jul 2, 2010 | 06:13 AM
Rovin4life's Avatar
obd one wont do squat. other then cleaning out your radiator and heater core with a hose and installing a new thermostat then you are fine. if you cleaned out everything and it still overheats then look at a fan clutch.
Old Jul 2, 2010 | 09:54 AM
Go on to , http://www.canobd2.com/Products/Tools.aspx , if you search you will find an OBD2 that also will work with OBD1's. If you like the idea, then go to Amazon.com and find the same scanner on sale for around $150 or so that will handle OBD1 and 2's.
Old Jul 2, 2010 | 01:47 PM
tweakrover's Avatar
??? I didn't say anything about my truck overheating, I just want to know if I can get any more info from a scanner that I can't get just reading the digital display I already have.
fishEH
Jul 15, 2014 05:23 AM
tweakrover
Jan 25, 2011 02:42 PM
calebbo
Jan 5, 2011 08:34 AM
rover
Freelander
Apr 28, 2008 08:42 PM
