OEM Radio question
Old Feb 21, 2019 | 03:46 PM
emtuzas's Avatar
Default OEM Radio question
I’ve purchased a D1 OEM Radio off ebay, it had "GB 4x4 radios" service sticker on it, seller said it was tested before selling and is in working order (hopefully). I Installed it recently and when trying to play anything, only when the volume is all the way up, I can barely hear music from one of the speakers. Aftermarket radio previously installed with converter-harness was putting out sound through those speakers without issues (minus tail door subwoofer). Logically thinking, it means the OEM radio is not in a working order, or could you suggest what to check before I send off the radio to be fixed, maybe there's an OEM amp somewhere remote, or some other cables I should check? Any input would be greatly appreciated. As always, Thanks!!!
Old Feb 21, 2019 | 06:04 PM
ihscouts's Avatar
OEM amp is under the passenger side kick panel. Sub amp is in the cargo door. I'd check the amp under the kick panel, probably bypassed because it's not needed with an aftermarket radio with its own amp.
Old Feb 22, 2019 | 08:47 AM
WaltNYC's Avatar
Grab the Electrical Troubleshooting Manual from the link in my sig ( etljyy0x.pdf yy=year of your truck ). In fact, grab all the manuals.
Old Feb 22, 2019 | 09:08 AM
emtuzas's Avatar
As always - thank you guys, will try to troubleshoot the damn thing this weekend!
Old Feb 22, 2019 | 10:13 AM
ihscouts's Avatar
That’s no way to start out the weekend......
Old Feb 22, 2019 | 10:40 AM
robertf's Avatar
hit the binnacle volume up switch to make sure its not muted that way
amp can be Under the passenger seat for 94/95, on the passenger kick panel for 96+, or under the drivers seat for the 98 LSE package
TURBOTICO
LR2
Nov 23, 2014 01:40 PM
Domrockstar
Dec 5, 2012 12:26 PM
SDinDS
Nov 21, 2010 08:32 AM
dbatie
Audio/Visual Electronics
Apr 10, 2009 09:36 AM
Canderson76
Nov 19, 2007 02:27 AM
