Oh why you keep leaking?!
Old Dec 19, 2025 | 01:44 PM
Ozark4WD's Avatar
Default Oh why you keep leaking?!
Well, i think I know why my front crankshaft front oil seal is leaking...what you guys think, time for crankshaft pulley sleeve? Is it SKF 99192?
Old Dec 19, 2025 | 02:47 PM
disco96sd's Avatar
yes speedy seal
Old Dec 22, 2025 | 10:52 PM
Mark G's Avatar
I'm not familiar with that seal. But an offset seal or even just no hammering one in all the way helps it ride in the different spot.
Old Dec 23, 2025 | 07:44 AM
Ozark4WD's Avatar
Mark, that's a basically sleeve on ring you are pressing on the shaft, so you can have smooth shaft surface again.
Old Dec 24, 2025 | 12:09 AM
Mark G's Avatar
Yours is definitely worn thats for sure. Let us know how it goes...
Old Dec 26, 2025 | 11:16 AM
Harvlr's Avatar
I think the term is "Speedy Sleeve", not "Speedy Seal". I think they're readily available at most auto parts stores. Bring your part in to get the correct size.
Old Dec 29, 2025 | 08:45 PM
disco96sd's Avatar
yes yes speedy sleeve - my local LR EXPERTS use them
Old Dec 29, 2025 | 10:39 PM
JohnZo's Avatar
The position of the sleeve is set by tapping it onto the shaft with a hammer and spacer. Good to make marks so the groove is pretty well centered with the sleeve. If the sleeve goes too far, you might need to try again with a new sleeve, because they stretch.
Brandon318
Jul 25, 2021 12:56 PM
Discorama
Apr 15, 2019 10:49 PM
DISCOFETA
Apr 2, 2019 06:38 AM
2Much_DISCO
Jan 29, 2013 08:34 PM
caleb
Jan 30, 2009 05:47 AM
