Oil Change and Belt squeak
Old Jul 9, 2011 | 03:29 AM
wheelgarage's Avatar
Default Oil Change and Belt squeak
Well, finally got around to changing the oil for the first time. Used a Wix oil filter, Liqui-Moly 10-40, and found an old new stock crush washer in my collection.
Man that oil was dirty.....from being under there, the steering box is really leaking and might be combination crank seal. After I change the fuel filter tomorrow morning, going to clean the entire area under the engine.
...man that's going to be friggin' dirty job....
Oil change done....started the car to get the oil circulated, then looked for that squeak around the belt assembly. Stopped the engine, chkd the oil, and lubed the tension pulley. Started it up again, squeak still there. I then grabbed my water bottle and sprayed the faces of the belt, squeak stopped. Checked belt alignment, good. Then looked at the belt configuration. It was off, belt mis-routed. Routed the belt correctly around the alternator and steering pump, then started it up. No more squeak!!!!
Sweet! Two more off the "SHEIT" list!
Old Jul 9, 2011 | 06:30 AM
Dont you love it when a plan comes together?
Old Jul 9, 2011 | 08:46 AM
tweakrover's Avatar
It is too easy to get the belt routed wrong, and it looks right and works sorta, which makes it worse
Old Jul 9, 2011 | 09:13 AM
honda50r's Avatar
And this is how we gain so much pride in our Rovers
Old Jul 9, 2011 | 01:32 PM
Lovin' it! I just hope the brake job goes smoothly next weekend. Going to buy the socket today....part of the plan.
sparky
Jun 6, 2015 10:01 AM
MrValingo
May 15, 2015 09:43 PM
swak6287
Mar 27, 2015 11:04 PM
jdwilks
Jul 24, 2014 09:09 AM
collin Barrows
Aug 28, 2011 07:13 AM
