Belt Squeak
Old Jun 14, 2007 | 03:06 PM
sparky's Avatar
Default Belt Squeak
I just had a new belt put on and in the morning it would squeal for just a minute then calm down. When I took it in to have it serviced the mechanic put some kind of belt spray on the belt. Well let just say that did not work because now it has amplified the problem. It squeals constantly when the air conditioner is turned on. I've tried putting baby powder on the belt but it doesn't work. Any suggestions?
TIA
Sparky
[align=left] [/align]
Old Jun 14, 2007 | 03:22 PM
98roverguy's Avatar
Default RE: Belt Squeak
You probably need a new belt tensioner. How many miles and has it ever been replaced to your knowledge?
Old Jun 14, 2007 | 04:26 PM
sparky's Avatar
I talked to Disco Mike by email and he seemed to think that may be the problem too. I'll be checking that this evening.
Old Jul 14, 2007 | 09:16 PM
disconz's Avatar
hello mate
i had the same prob,sprayed loads of lube on tensioner, no change, got worse when under load ,the prob got solved in 5 mins when i took it to a landrover mechanic to have the cats cut, he opend the bonnet and said (hay another belt running the wrong way!) this also made the waterpump run backwards,i didnt think of checking asit was on the car when i gotit . anywaymay be a bit obvious but hope it helps..........
Old Jul 15, 2007 | 07:44 AM
Sparky,
There really isn't much to test on a tensioner. I would suggest you go buy a new one along with a idler pulley and you'll be fine.
By the way, never let anyone put belt dressing on a noisy belt, it will build up a film on the pulleys that will come back and haunt you for years.
Mike
Old Jun 1, 2015 | 11:51 AM
jasonRedRover's Avatar
Quick follow up on this: Do you consider "Belt Conditioner" (I'm using CRC belt conditioner) the same as "belt dressing"?
Also, if you get something like that on the belt, and it's a bad idea, how to remove? Brake Cleaner?
Old Jun 1, 2015 | 12:14 PM
drowssap's Avatar
A quick follow up on a 7 year old post, timely very timely
Old Jun 6, 2015 | 10:01 AM
Thanks for the help @drowssap! j/k
for anyone caring - don't ever use the "Belt Conditioner" - left crap on my jockey pulley
new Gates belt from O'Reilly's solved it - now she purrs...
MrValingo
May 15, 2015 09:43 PM
swak6287
Mar 27, 2015 11:04 PM
jdwilks
Jul 24, 2014 09:09 AM
wheelgarage
Jul 9, 2011 01:32 PM
sna77
Nov 18, 2008 06:23 PM
