What else makes a belt/pulley squeak sound?
Old Jul 23, 2014 | 02:48 PM
jdwilks's Avatar
Default What else makes a belt/pulley squeak sound?
So if my car has set a few days and I first start it I will get that pulsating squeak/chirp that sounds to me like a pulley sound from previous cars. Its not to loud but enough to annoy me. It goes away after a minute or two. I replaced the belt and replaced the 3 idler and tensioner pulleys and the noise remains. I know first thing I need to probably do is take off the belt and check for play but have been lazy. With hood open sounds like water pump or AC area but that not positive on that. Just curious if anyone else has had similar issue or other things to check possibly
Will add it doesnt change or go away with rpm's
Old Jul 23, 2014 | 02:53 PM
jamestfl's Avatar
power steering pump?
Old Jul 23, 2014 | 04:44 PM
primussucks's Avatar
leaking coolant from the bleed screw
Old Jul 23, 2014 | 07:07 PM
QuakerJ's Avatar
Sometimes the fan clutch can make those sounds. Try rotating it by hand a few times. Have to eliminate possibilities at this point, and you will eventually find the culprit.
Old Jul 23, 2014 | 08:39 PM
dr. mordo's Avatar
The fact that it doesn't change with rpms is weird.
Old Jul 24, 2014 | 03:04 AM
siber54's Avatar
Default hmm
Well on a side note I thought my belts were chirping one time but it turned out to be that the 2 upper ujoints on my front drive line were very bad. Also mine only squeeks not when I first start but only if ac is on.
Old Jul 24, 2014 | 09:09 AM
jamestfl's Avatar
"Also mine only squeeks not when I first start but only if ac is on."
ewww, compressor bearings?
sparky
Jun 6, 2015 10:01 AM
MrValingo
May 15, 2015 09:43 PM
swak6287
Mar 27, 2015 11:04 PM
wheelgarage
Jul 9, 2011 01:32 PM
mimimi
Aug 9, 2007 07:56 PM
