oil drain plug size?
I don't know the thread size but you need a 29mm wrench for the hex head.
Also, I would say the valve is a bad idea. Any shmuck that had a beef with you could come along and ruin your engine by draining your oil without you knowing. I seem to recall Fram hada "Quick Change" kit a few years back that was a valve to install. Not sure why exactly it isn't made anymore but they probably realized it was a bad idea.
Amen. Because EASIER does not always equal better!
Just like back when I was in the oil changing business, I remember seeing those rubber "quick-release" drain plugs. They were used mainly for stripped out threads. I used to throw them away and install a real drain plug (half millimeter oversized, self-tapping). Saves the cost of having to buy a whole new oil pan.
Wow really? Thats not "snippy", and I'm not talking about consumer garbage, anything fram sells is trash. I mention something that's put on all caterpillar engines and you jump to that? These are on pretty much every piece of off highway equipment cat makes with exception of skid steers, and none of those have problems because its well built and designed for extreme environments. I'm not talking about crap people put on their Hondas haha. Now how bout some actual help, rather then being talked down to? It's not just the mess, it's ease of things. I work 50+ hrs a week with an hour drive either way and most he time have work at the church to after, so anywhere I can save time helps.
I wasn't saying the part you were using was junk or that it wouldn't work. I personally don't think the benefit of saving literally 2 minutes is worth the risk of someone draining your oil.
When changing the brake rotors takes hours of labor I really coolant care about saving 2 minutes by not having to unscrew a drain plug.
Let us know what you come up with though.
I have these on the vehicles here in the shop and they are offered in a couple of different configurations to make collection easier. On the duallys we use the one with the nipple so a hose can be attached and drained directly into a resealable container. I have thought about adding one to the D1 so when the oil is hot it can be quickly drained and easily transported to the storage container and processed to go back into one of the WO burning vehicles here. We have never had an instance of someone tampering with the drain on any of the vehicles and honestly, if they plan to climb under a vehicle for some retaliation purpose; they will most likely be prepared with suitable means to remove a plug and will be surprised to find a valve such as this. They might not even know how to operate the valve.
The issue I see with using one of this brand is that they go straight and if you add the 90 adapter it might be too close to the cat/exhaust.
http://www.qwikvalve.com/F-101-1-2-20UNF.html
