oil drain plug size?
Old 10-04-2012, 10:20 AM
EricTyrrell's Avatar
Are you confirming the plug thread size is 1/2"-20 UNF?
Old 10-04-2012, 11:47 AM
dansgt's Avatar
Exactly what I'm looking at, but likely not the flat one. They make them for cat and several other brands. If your worried about someone tampering with your oil you've got other problems, either way my cars are kept in the garage. Beside that they have to go under to see that it's even there AND have something to drain into, otherwise it's pretty obvious what's going on. If you see a giant oil spot and don't check, you deserve to buy an engine lol
Old 10-04-2012, 11:54 AM
Rover_Hokie's Avatar
Like this one?
http://www.nospillsystems.com/design-spec
Old 10-04-2012, 02:03 PM
dansgt's Avatar
I'm gonna see if the parts depo at the cat dealer I work at has one.
Old 10-04-2012, 09:34 PM
How often are you changing your oil Dansgt?
Old 10-09-2012, 11:51 AM
dansgt's Avatar
3-4 times a year? Between the 3 cars I'm constantly working on one of em. Though I've got alternator issues again (couple bad used ones,put together one working one but it cut out again), so this will probably get out on hold again and just do normal.
Old 10-09-2012, 12:05 PM
re: I'm constantly working on one of em
Service activities increase by the square of the number of vehicles owned, multiplied by the number of days left until payday.
Old 10-09-2012, 01:35 PM
binvanna's Avatar
I've got to agree that the drainplug is a bummer. Even if you point it the right way, it still pours oil all over your hand when you pull it out. I'm not whining about a little mess. I can use a latex glove, a little more finesse or whatever, but it could be better. The oil filter is super easy to access. Sure can't complain there. But I do wish it wouldn't always dump a little onto the front differential cover.
On the Land Rover you have to watch out for British Standard Pipe, and British Standard Pipe Parallel threads, ala the radiator or diff plugs. The Buick motor is mostly SAE but the oil pan could be Anglified.
Old 10-09-2012, 01:47 PM
fishEH's Avatar
Not really. I position my hand above the drain plug. Then I unscrew it using my thumb and index finger(that are pointing down). No mess.
Old 10-09-2012, 05:22 PM
ValveCoverGasket's Avatar
yup! all about undoing the last couple threads with your hand above the plug.
Quick Reply: oil drain plug size?
