oil leak
Old Jun 11, 2015 | 09:19 PM
TOM R's Avatar
Default oil leak
After the rebuild this is my last oil leak oil is definitely coming from that freeze plug looking disc behind the oil filter, thoughts?
Old Jun 12, 2015 | 08:01 PM
TOM R's Avatar
Anyone have a timing cover off to look and see if that's removable for reseal or what
Old Jun 12, 2015 | 08:31 PM
ihscouts's Avatar
On early 3.9's that was held in with a snap-ring, small puck sealed with O-ring. On the newer engines it's a hammer in plug. It's a drilling to install the oil pressure bypass spring at the factory. First see if an auto parts palace has a plug that small and then pop out with a screw driver like you'd do for freeze plugs.
Old Jun 12, 2015 | 08:38 PM
TOM R's Avatar
My case tractor has similar by the oil filter, need to think where I put them ( had to buy a bag for 1)
I mean if that's leaking can't be good long term
Old Jun 12, 2015 | 08:47 PM
ihscouts's Avatar
Depends how much it's leaking. Man if you got all your oil leaks down to just that we're ready for living on Mars. Funny how a tractor comes into the picture when talking about a Rover.
Old Jun 12, 2015 | 09:22 PM
TOM R's Avatar
Case from the 50s overhead valve 4cyl gas
Old Jun 18, 2015 | 01:38 PM
landy_ala's Avatar
People tell me all the time that my Rover is leaking but I have to tell them is a Land Rover design. It is call constant flushing haha. Anyways you could remove the plug and tap that hole for a threaded brass plug since all it serves is an access for the spring.
Old Jun 19, 2015 | 01:57 PM
Best4x4's Avatar
Are you 100% sure the leak isn't coming from above and pooling in that plug? I had what looked like an identical situation on my 98 D1 and actually the leak was coming from the Oil Pressure switch, leaking out, and collecting in that plug area before dripping down the oil filter and finally the ground.
I found it by wiping the area completely dry, then driving it, shutting it off, and looking for a trail of oil and sure enough I could trace it back to the oil pressure switch Oring. I slapped on a new sensor for 15.00 and I have been leak free since. Just something to double check.
Old Jun 19, 2015 | 03:55 PM
TOM R's Avatar
replaced the oil switch and oring to fix that leak last year, just rebuilt the engine 1k miles ago or a few weeks back depending on how you want to look at it lol and everything is clean and dry except that cap and its running down dripping off the filter , truck was on a lift so i could look real good
it will probly stay unless there is a chance it could blow out or i decide to pull the cover and do a cam later
Old Jun 19, 2015 | 04:10 PM
Best4x4's Avatar
Okay just making sure
thearmlesswonder
Jul 27, 2015 10:16 AM
Phatrowles
Jan 9, 2014 10:36 AM
shonuff93
Mar 28, 2012 09:33 AM
tito5590805
Sep 27, 2010 11:32 AM
rgrizzard
Mar 6, 2008 10:16 AM
