Oil light after sustained high rpms
Old Dec 12, 2016 | 01:40 AM
MrValingo's Avatar
Default Oil light after sustained high rpms
So when me 98 d1 is all warm n cuddly and I've been out beatin on her doin figure 8's in the snow or spinning tires in the mud, I'll get a few flickers of that red oil can on the dash. But only after she's back down to idle and it's been above 4K...5k...well it's been above normal operating range longer than advised. Any thoughts? Besides hey don't do that. Cuz I done did that.
Old Dec 12, 2016 | 02:15 PM
fishEH's Avatar
What are your RPM's like when the light flickers? Sometimes after revving real high and letting off the idle will drop below the 600-700 norm. Low idle rpm can produce low oil pressure.
Old Dec 12, 2016 | 03:00 PM
MrValingo's Avatar
id say 700-900rpms.
Old Dec 12, 2016 | 08:15 PM
Charlie_V's Avatar
Oil pump or some sort of bearing problem.
​​​Put a bigger oil filter on and switch to a thicker oil to hide the problem for awhile.
Old Dec 12, 2016 | 09:47 PM
MrValingo's Avatar
I like your style
Old Dec 12, 2016 | 10:03 PM
Jagfixer's Avatar
Might check under rocker covers and see if oil return holes are clear. Maybe after high RPM the oil is not draining from heads to pan as it should.
Old Dec 13, 2016 | 12:39 AM
Charlie_V's Avatar
Originally Posted by MrValingo
I like your style
Old Dec 13, 2016 | 09:04 AM
MrValingo's Avatar
Heads were pretty dirty when I opened her up about 5k miles ago. Cleaned everything pretty well but some gunk elsewhere could have come dislodged
JumPeR04
Aug 9, 2012 03:37 AM
aemnky606
Apr 22, 2010 07:50 AM
free_kid
13
Feb 3, 2010 12:56 PM
tommytwotone
Aug 6, 2008 10:07 AM
tads
Jun 6, 2007 01:20 PM
