Oil Pan Gasket Recommendation Needed
Old Mar 18, 2017 | 04:06 PM
colemtd's Avatar
Originally Posted by ihscouts
Funky Cole long and lanky, little love goes a long ways lady.......howdy! I do miss speaking with the Master, I do. When you gonna get that 2017 Range Rover Dr. Cole? Happy Women's Day!
Ha Ha.. Thanks!
Old Mar 18, 2017 | 04:54 PM
colemtd's Avatar
Default RTV Question
Hi All, how much RTV do you use (apply thickly or thinly) and once you put everything back together how long do you wait until you start the engine?
Old Mar 18, 2017 | 06:12 PM
ihscouts's Avatar
There is a product called "Right Stuff" that works way better than RTV. Permatex The Right Stuff Gasket Maker 5 oz. | Staples® Right Stuff is almost a glue, it bonds the pan to the motor. Excess RTV if applied too thick squishes out, will eventually end up in the bottom of the oil pan where the oil pump pick-up screen is. That screen if blocked will reduce the amount of oil going to the pump and that means it reduces the pressure to push into the many small galleys throughout the motor to keep things from touching one another. If you're going to use RTV use as thin a bead as possible so that it doesn't "squish" over the lip of the pan. Thin works best, let it "skin" before putting the pan back on.
Old Mar 18, 2017 | 08:46 PM
ihscouts's Avatar
Something I just thought of, you'll want to clean both the bottom of the motor where the gasket material is going to seal and the oil pan lip. I use this for cleaning metal surfaces; Klean-Strip 32 oz. Methyl Ethyl Ketone (MEK) Solvent-QME71 - The Home Depot It's a very strong solvent that dries quickly.
Old Mar 18, 2017 | 11:12 PM
colemtd's Avatar
Thanks Scouts but after you put the pan back on how long do you have to wait before you start the engine?
Old Mar 19, 2017 | 09:16 AM
OverRover's Avatar
If you are using the Permatex Ultra Black or Gray then full cure takes 24 hrs. I think Right Stuff is the same, but you can get all the info you need here >
https://www.permatex.com/products/gasketing/ultra-series-gasket-makers/permatex-ultra-black-maximum-oil-resistance-rtv-silicone-gasket-maker-4/
Old Mar 19, 2017 | 10:03 AM
ihscouts's Avatar
Whatever you're using - read the label......
Old Mar 20, 2017 | 12:46 AM
colemtd's Avatar
Thanks so does that mean that I can't start the car for an hour or I should wait 24 hours to start the car?
Old Mar 20, 2017 | 12:51 AM
colemtd's Avatar
Thanks but WWSD? LOL!
Hmmm.. What Would Scouts Do.. Would you wait 24 hours to start it up or how many hours would you wait to start it up and drive it?
Old Mar 20, 2017 | 02:13 AM
ihscouts's Avatar
Really?
I'd let it cure overnight and drive it the next morning.
......it would start with a shiver.
That's what I'd do........ who's Scouts?
