Oil Pan Gasket Recommendation Needed
Old Mar 20, 2017 | 11:50 AM
  #21
colemtd's Avatar
Originally Posted by ihscouts
Really?
I'd let it cure overnight and drive it the next morning.
......it would start with a shiver.
That's what I'd do........ who's Scouts?
OK thanks.. LOL Scouts is you!!
Old Mar 20, 2017 | 12:13 PM
  #22
ihscouts's Avatar
Awe Mom, just let me be Satan for a minute would ya, I never get to have any fun.......
Old Mar 20, 2017 | 03:00 PM
  #23
colemtd's Avatar
OK consider your wings clipped
Old Mar 21, 2017 | 07:59 PM
  #24
ihscouts's Avatar
Just sunk in, "clipped wings". You deserve a hug.
Old Mar 21, 2017 | 08:06 PM
  #25
colemtd's Avatar
Thanks! I'll check back in to report on the results...
Old Mar 21, 2017 | 08:11 PM
  #26
ihscouts's Avatar
Are you gonna wait until the weekend?
Old Mar 21, 2017 | 08:12 PM
  #27
colemtd's Avatar
Yup. It'll be next weekend..
Old Mar 21, 2017 | 08:17 PM
  #28
ihscouts's Avatar
Thank you cuz I gotta pee and I can't wait that long to go. Big dirty project, if you nail it you get two hugs. No pressure......
Old Mar 21, 2017 | 08:20 PM
  #29
colemtd's Avatar
Old Mar 21, 2017 | 08:28 PM
  #30
ihscouts's Avatar
I'm back, WHEW! Your gonna have to get gloves that go to the shoulder........ the hardest part will be trying to seal the back of the pan, very thin motor casting at the back of the skirt, hardly anything to seal to. The DII went with a cast aluminum oil pan, which is a little better since it doesn't deform like the D1's steal pan at the bolts. The other thing about the D1's is the lip does deform, usually from over tightening the mounting bolts so try straightening the lip as much as you can. I use a straight edge, a steel ruler but anything that's straight will do. Channel locks work to bend the lip and a hammer and dolly to straighten/flatten where the bolts mount through. Another thing is the bolts I believe use a lock washer but they don't really do the trick. I use Locktite red to make sure the bolts don't loosen. You'll have to clean them for that to work, carb cleaner or the MEK works.
