Oil pressure gauge installed
Old Apr 21, 2014 | 08:50 PM
ftby55's Avatar
8th Gear
Default Oil pressure gauge installed
Have just finished install of oil pressure gauge and checked operating pressure.
FRAM GOLD Filter, Rotella 15W40
Start cold 41 psig
Idle cold 41 psig
2500 cold 42 psig
Idle hot 20 psig
2500 hot 40 psig
In gear hot 17-19 psig
Are these good operating pressures?
Old Apr 21, 2014 | 09:46 PM
mordor110's Avatar
I installed one on mine back in 2008. Your pressures are 1-2psi higher than mine, so I'd say it looks very good. I'm running 10W40 Castrol. What was the ambient. My pressures run slightly higher in the winter, slightly lower in the heat of summer with 10W40. 20W50 gives me better pressure in the summer but horrible pressure in the winter when the engine is cold.
Where did you tap in at, the OEM pressure switch? That's where I tapped in. Made up a "special" tee piece so I could keep the stock idiot light sensor also.
Old Apr 22, 2014 | 09:41 PM
ftby55's Avatar
8th Gear
I purchased the sandwich adapter that goes between the oilfilter and block.
Today driving at 3000 rpm 35-37psig when at temperature but when I let up on the gas it increases to 40 psig while coasting. Strange.
Old Apr 23, 2014 | 06:06 AM
RedRovin''s Avatar
Do you have a link to the products you purchased? I'm interested in buying one.
Old Apr 24, 2014 | 07:58 PM
ftby55's Avatar
8th Gear
gloshiftdirect.com http://www.glowshiftdirect.com
ralphobell
May 20, 2012 03:14 PM
Discolife
Nov 23, 2011 07:58 PM
lipadj46
Oct 17, 2010 06:34 PM
jycsalas
Mar 19, 2009 07:42 AM
Fonzie
Oct 15, 2007 01:47 PM
