Oil Pump Rebuild
Oil Pump Rebuild
Please tell me if I'm doing this correctly. This is an authentic Land Rover rebuild kit.
Old oil pump gears
Removed old gears and packed with grease
Installed new gears
It appears there's no "front" side to the gears?
The new center gear does not sit flush with the other new gears. However, on the old gear set, it does sit flush. You can see this in the photos. Is this correct?
Old oil pump gears
Installed new gears
Actually I don't know. I'll be replacing mine soon though.
If you don't get a satisfactory answer, ask on this forum Land Rover UK Forums
I know there are several who've done it.
It doesn't seem right to me though.
The center gear is not removable because of small indentations that are pressed into it. They allow it to float in the middle, but not fall out. The indentations on the new gears appear to be slightly larger.
My current theory is that it doesn't matter, either because the gear is supposed to float somewhere in the middle anyways, or because the indentations will eventually wear corresponding indentations into the receiving gear, thereby making them flush.
New gears:
Old Gears:
New gears:
Old Gears:
