Oil Pump Rebuild
Old Nov 17, 2011 | 10:50 PM
EricTyrrell's Avatar
Default Oil Pump Rebuild
Please tell me if I'm doing this correctly. This is an authentic Land Rover rebuild kit.
Old oil pump gears
Removed old gears and packed with grease
Installed new gears
It appears there's no "front" side to the gears?
The new center gear does not sit flush with the other new gears. However, on the old gear set, it does sit flush. You can see this in the photos. Is this correct?
Old Nov 18, 2011 | 03:20 PM
Has anyone even ever done this? I know it's not gong to be as popular as changing your plugs
Old Nov 18, 2011 | 04:28 PM
Danny Lee 97 Disco's Avatar
Maybe not as many opinions but yours is a lot more critical, I want to know as well. I bet Tom Rowe will KNOW. He usually does, Tom give a hollar.
Old Nov 18, 2011 | 04:36 PM
adigerol77's Avatar
I'm offended by your comment.
Old Nov 18, 2011 | 06:05 PM
wheelgarage's Avatar
The only thing i can see that might go wrong is when the main pulley is back on. The pulley might be out a few millimeters, which could cause issues with belt alignment.....
Old Nov 18, 2011 | 06:47 PM
antichrist's Avatar
Actually I don't know. I'll be replacing mine soon though.
If you don't get a satisfactory answer, ask on this forum Land Rover UK Forums
I know there are several who've done it.
It doesn't seem right to me though.
Old Nov 18, 2011 | 08:58 PM
Can you photo side by side new center gear and old center gear (the part sticking up is "new" and part of the "new" set?)?
Old Nov 18, 2011 | 09:08 PM
Here's a pix from DeepBlueWater, it looks like his is pretty close to "flat" as well.
Old Nov 18, 2011 | 09:32 PM
The center gear is not removable because of small indentations that are pressed into it. They allow it to float in the middle, but not fall out. The indentations on the new gears appear to be slightly larger.
My current theory is that it doesn't matter, either because the gear is supposed to float somewhere in the middle anyways, or because the indentations will eventually wear corresponding indentations into the receiving gear, thereby making them flush.
New gears:
Old Gears:
Old Nov 18, 2011 | 09:35 PM
That does look pretty flat, but I wonder what the new set looked like.
