Oil Pump/Timing Chain Replacement/Water Pump Install Job
I'm going to be doing an oil pump/Timing Chain Replace/Water Pump Replacement job soon. I'm just looking for any tips, hints, or tricks from those who've done the job before.
Thanks
Thanks
Alex_M did a great write-up with pics on doing this service on a DII.
Basically the same procedure for a DI just a few less bits to remove.
Have a look >https://landroverforums.com/forum/di...38/#post548912
Your pick up tube will not have an o-ring and will go into the block, not the cover. This is because of the GEMS engine. Be sure that you clean the screen and tube as best you can. I didn't replace the studs with bolts as the nuts and studs work fine for me. Be sure to check out that post it will answer a lot of other questions for you.
Check out my recent write-up:
Hi Everyone,
I have posted a write-up of my recent adventure in replacing the front engine cover gasket and other bits hidden behind it. Feel free to review and use, it was a success! I hope it is helpful!
1998 Discovery I LSE, GEMS V8
https://www.dropbox.com/s/b41vebtxto...COVER.pdf?dl=0
Cheers,
Jackyak
oil pump, timing chain, oil pan gasket, front engine cover,rotella
Cheers,
Jackyak
CaptainCulp
Dec 13, 2014 07:23 AM
