And the other shoe falls off...
Old Apr 21, 2012 | 09:19 AM
RobertBrowning's Avatar
Default And the other shoe falls off...
g'morning... i get truck running and now i can't put it into gear... LOL... anyway gonna check to see if there is a brake switch/wire that is faulty not allowing the automatic gear shift to move... any advise?
on a side note... is it pretty simple to replace stereo in a 97 Disco?
Old Apr 21, 2012 | 09:50 AM
priceg's Avatar
Buy the install kit for your new radio, the plastic fascia on the old Discos is super brittle and wont support much. There is a aluminum shelf that the factory radio sets on, but it is screwed to the plastic fascia. You will need a 2.5mm allen to remove the factory radio. Good luck
Old Apr 21, 2012 | 09:54 AM
ngarover's Avatar
Check to see if you have a blown fuse. Off the top of my head I can't remember which one it is, but there is one that if blown, will lock you out from being able to move the auto shifter. Has happened to me.
Old Apr 21, 2012 | 09:56 AM
May also just be a fuse - see attached pages from RAVE, BTW it would help if you include your truck year and miles in the signature.
File Type: pdf
Old Apr 21, 2012 | 10:48 AM
checked breakers... no love... going 2 follow path as per provided diagram (thx again - as usual Savannah Buzz)...
Old Apr 21, 2012 | 10:51 AM
priceg's Avatar
Check to see if you have brake lights
Old Apr 21, 2012 | 10:58 AM
good call, priceg... tested all lights last night and they were good... no lights now... do you think a disco can be allergic to a Full Tank of Super Unleaded? :}
Old Apr 21, 2012 | 11:12 AM
priceg's Avatar
The brake light switch on the pedal supplies an input for the shift interlock solenoid. Part of the self adjuster fails so it does'nt lock into place. I have glued them in a pinch situation.
Old Apr 21, 2012 | 11:42 AM
will try it, priceg... is there a proper way 2 fix it?
Old Apr 21, 2012 | 11:49 AM
priceg's Avatar
No, replacement is the only option. You can remove it from its holder with it plugged up and manipulate it with your finger to get the trans out of park, however your brake lights will still be inop.
