Over heating 96 disco
Old May 29, 2011 | 03:20 PM
jmagsdad's Avatar
6th Gear
mine is the clear version but that sounds very much like my problem.. i will start there... if i can find one that is... discos are hard to come by salvaged at least in NE TN. Thank you all.. i just got home from buying a new 195 degree thermostat and it came with a paper gasket although the one I took out didnt have a gasket.. looks like someone before me made a gasket with some type of apoxy.. on the engine side not the hose side.. should I attempt to put the paper gasket on.. it doesnt leak there now with no thermostat in the housing..
thanks again
Old May 29, 2011 | 03:35 PM
You need to scrap off all of the RTV that they used and then make sure it is dry and then use the paper gasket.
Old May 29, 2011 | 04:19 PM
antichrist's Avatar
Read this:
https://landroverforums.com/forum/di...e8/#post208408
Old Jun 1, 2011 | 12:46 PM
jmagsdad's Avatar
6th Gear
ok.. so i replaced the thermostat, and the radiator fill tank and bam...im back in buisness.. thank you all for the help... greatly appreciated
Old Jun 3, 2011 | 07:25 PM
Optimistic.1's Avatar
From my experience with my 98, it sounds like your radiator is clogged. Mine does the same thing...I'm looking for a radiator right now as I type....lol
SolbergFanBoi
Mar 5, 2012 07:05 PM
jennifer
Nov 17, 2008 09:26 AM
skikir
Feb 1, 2008 10:33 AM
lillaidypink
Dec 23, 2007 12:06 AM
