Overheating Problem Solved
Old Aug 3, 2010 | 12:35 PM
rgbeard's Avatar
7th Gear
Thumbs up Overheating Problem Solved
Thanks to everyone who posted all of the helpful tech tips on the overheating issues. I have finally solved mine.
Three things to correct and you should have it all solved for under $100 bucks.
1. New thermostat $10
2. Verify serpentine belt is routed correctly. Mine was not after water pump was replaced.
3. Replace the fan clutch w/ Chevy part listed in tech sticky.
** One note on the clutch replacement. My fan housing was rubbing the blades so I went with 3/8 bolts @ 3/4" length. Inserted lock washer between the clutch and blade to increase the gap and eliminated the rub.
Running like a champ @ 1/2 on the temp gauge with A/C running. Current temp in South Georgia is 100+ with heat index over 110. I'm in heaven even in traffic.
Thanks again to all the help guys. Wish I could buy you all a cold one.
Old Aug 3, 2010 | 05:46 PM
Thank you for reporting back.
Glad all is well once again.
ajh
Aug 25, 2015 07:43 AM
Karl Freund
Jun 22, 2012 05:24 PM
Princess
Sep 6, 2011 09:14 PM
Atl
Apr 7, 2010 05:39 PM
kma32254
May 28, 2009 12:00 AM
