P1138 and hesitation - 96 Discovery SE
Old May 18, 2018 | 08:58 AM
mware18's Avatar
Default P1138 and hesitation - 96 Discovery SE
At start up this morning car started to miss at idle and hesitate when accelerating up hill. The hesitating did get better as I continued to drive and the engine became warmer. It has been missing some at idle this week with no visible dip in RPMs but did not hesitate while driving. I do get a random CEL for P0138 but it is on again off again.
Checked code when I got to office and it was a P1138 - Manufacturer fuel air metering.
Any thoughts on where to start? Plugs, Wires, Mass Airflow Sensor? Maybe all of the above.
Thanks,
Mitt
Old May 18, 2018 | 09:53 AM
whiskeynipple0088's Avatar
foggy and damp this morn?
me too - mine is from a cracked coil pack I have yet to replace
Old May 18, 2018 | 09:55 AM
mware18's Avatar
It was damp after some heavy rain last night. I am guessing o2 sensors for mine as well. I will take a look at coil pack.
Thanks,
Old May 18, 2018 | 10:02 AM
do it when its dark out - you may see the actual arc
check your spark plug wires too - if they are old and cracked - could produce same issue
personally - I would reset the codes after getting this sorted then see if you still need a o2
Old May 18, 2018 | 11:40 AM
mware18's Avatar
Leaking injector?
Faint smell of raw gas when I started it up to go to lunch.
binvanna
Apr 8, 2017 12:31 PM
Soul97
Feb 16, 2014 07:20 AM
15degreeGTI
May 16, 2013 02:30 PM
philander
Aug 19, 2011 04:20 PM
Corsair33
Sep 1, 2006 12:13 PM
