p1179
Old Sep 1, 2014 | 01:50 PM
  #21
TOM R's Avatar
no not gonna rig it up if it needs the fpr I will buy it, I drive to much to rig up certain things lol
just wanted to be sure before I spend the $ on a part that I actualy need the part
Old Sep 1, 2014 | 05:11 PM
  #22
TOM R's Avatar
well ordered a new fpr so guess next week we will know if it worked or not, if not guess we are missing the Vermont expedition with our rover club :P
Old Sep 4, 2014 | 07:49 PM
  #23
TOM R's Avatar
New fpr installed seems fixed also threw in the the used Volvo injectors
Old Dec 15, 2014 | 02:55 AM
  #24
TOM R's Avatar
Well code is back but engine runs fine???
Old Dec 15, 2014 | 07:16 AM
  #25
Shiftonthefly1's Avatar
Any way to get a pressure reading before the rail? Maybe makeshift temp port tapped in? I'd be curious about those "nasty" fuel lines you mentioned. Maybe restricted flow?
Hard to tell if your chasing a physical problem or a false reading/electrical problem.
Old Dec 15, 2014 | 09:40 AM
  #26
TOM R's Avatar
Need to get time for fp reading, runs fine, drinking gas though
Well I guess I need to unhook that line at both ends and blow it out, wonder if the rubber part could be collapsed inside
Old Dec 15, 2014 | 10:39 PM
  #27
I had a Ford Bronco once that ran rich as hell then lean as hell. After wrestling with sensors and computer crap (obd1) I found one of the lines off the pump on top the tank was collapsing inside. Took me forever to figure it out. It was only out of desperation that I finally started throwing parts at it. I had removed the gas tank twice and replaced the pump twice. Never saw the bad line. I must have replaced every sensor twice on that truck. Haha
Old Dec 16, 2014 | 12:24 PM
  #28
TOM R's Avatar
You know, when I did the fuel pump I removed the clear tubing in the assembly and replaced it with rubber fuel injection line, wonder if that's breaking down from being submerged in the tank
It is in a loop so it does not kink
Old Dec 17, 2014 | 03:20 PM
  #29
I thought fuel injection line was safe to do that with.
Old Dec 17, 2014 | 07:37 PM
  #30
TOM R's Avatar
Me too thats why I dI'd it
