A-Pillar Finisher ?
Old Feb 5, 2018 | 12:44 PM
Matt927's Avatar
Default A-Pillar Finisher ?
Hi,
How is the rubber A pillar finisher held in place? I understand getting it out will more then likely destroy the old piece but is installing the new one straight forward?
I am trying to gain access to the right upper corner of the roof/windshield area.
Thank you,
Matt
Old Feb 5, 2018 | 01:05 PM
Sixpack577's Avatar
3 metal clips
It just pushes on
Old Feb 6, 2018 | 10:51 AM
WaltNYC's Avatar
edited... I was on 'the wrong page' removed to avoid confusion
Old Feb 6, 2018 | 07:48 PM
Matt927's Avatar
Walt,
Now that I see the piece I see what you mean. Any adhesive used for installation besides the strips already on the piece. Tap in with a mallet?
Old Feb 7, 2018 | 11:29 AM
WaltNYC's Avatar
ditto
Old Feb 7, 2018 | 12:02 PM
Matt927's Avatar
I am referring the exterior piece, AWR2023. Anyone have any ideas? Wondering if they are set onto the windshield edges prior to installing a new windshield?
Old Feb 7, 2018 | 12:24 PM
Sixpack577's Avatar
Not sure what part that number is, but the windshield goes in first. Then the lower cowl under the wipers.
The 2 small top corners slide on to the drip rail.
Then 3 metal clips get pushed on to the long plastic side trim pieces. Those pieces then snap into the metal frame on each side of the windshield.
chubbs878
Feb 11, 2017 01:18 AM
jna97
Dec 31, 2016 04:13 PM
Twins Disco
Dec 16, 2013 01:50 PM
ralphobell
Apr 1, 2013 11:09 AM
skins
Aug 20, 2006 01:17 AM
