Pipe Low Rad-Trans Disco I Auto UBP 101030
Old Dec 15, 2025 | 01:26 PM
Ozark4WD's Avatar
Talking
Originally Posted by WaltNYC
Absolutely try to fix leaks without using a crazy amount of RTV/silicone. Those transmission cooler hoses are a pain and mine always leak a bit, as do the steering pump lines. ATF is a solid anti-corrosion fluid.
All that said please remember.... If it doesn't leak, it is empty!
I overachieved on that one for sure, and overachieving is worse than communism, but i will correct myself when working on the front cover again!
Old Dec 16, 2025 | 11:43 AM
WaltNYC's Avatar
hylomar is a great product for the front cover. A thin (2-3 mm) line on each side of the gasket works very nicely.
Also, there are some outfits that sell a paper version of the gasket. Other sell the thicker 'cardboard' version (like a water pump gasket). I used the thicker version fwiw.
Old Dec 17, 2025 | 10:21 AM
Toran's Avatar
Originally Posted by JohnZo
If push comes to shove, the ATF cooler hoses can be renewed at a hydraulic repair shop. I noticed the kit of three hoses from Roverparts is out of stock. The drips in the photo look like coolant, not ATF, so could be water pump or timing cover coolant leaks.... Some forum members, like me, run the trucks unpressurized to help prevent coolant leaks. Ensure coolant concentration, then simply loosen the reservoir cap to unpressurize the cooling system.
Hello Good People,
Good to to see the forum help is thriving with positive feedback.
Hey JohnZo, I appreciated your feedback in a previous post on the unpressurized setup.
Question: tighten the coolant cap than back it off by a quarter turn? Half turn?
Sorry about the repeat. Sadly I don't want to be this person, yet I am the person that often is laughed at because I am slower than others in understanding the differences between pegasus and unicorn. Both are mythical horse-like creatures, but they differ in origin, appearance, and symbolism.
Thank you
Old Dec 17, 2025 | 11:56 AM
Ozark4WD's Avatar
Originally Posted by Toran
Hello Good People,
Thank you
There is a great article written on this by the forum member on his blog here: https://extinctmotorsports.com/the-e...s-10-min-read/
He explains how to do it and all the pros and cons of doing that. I'm running my disco now in this manner too.
Old Dec 17, 2025 | 02:38 PM
Toran's Avatar
I read the article just want to know exactly how far your backing off the coolant cap?
Old Dec 17, 2025 | 02:52 PM
Ozark4WD's Avatar
First i twist it to full close - then i back one full turn out.
Old Dec 17, 2025 | 04:16 PM
Toran's Avatar
Cool, I'll give it a go.
Thanks
Old Dec 21, 2025 | 07:56 PM
JohnZo's Avatar
Toran, I hope this is working for you. The concept is that the rubber gasket barely makes contact, so pressure does not build up, coolant does not splash out, and dirt does not fall in. I replaced the cap on one vehicle with the poly insert that came with a new translucent tank, fashioned a simple vent hole.
Old Dec 21, 2025 | 10:25 PM
Toran's Avatar
Hey JohnZo,
Good to hear from you!
I did not mean to hijack this thread, got so excited and equally curious. If your time permits please share an image of your modified cap. An image is worth a thousands words.
Words are my 2nd language, my first is images.
Thanks
merebel
Jun 22, 2021 07:32 AM
beebe
Range Rover L322 (3rd Gen)
Dec 26, 2020 08:53 PM
TRIARII
Nov 28, 2013 02:46 PM
sickdisco
Jul 17, 2013 06:51 AM
nordic
Sep 28, 2010 10:32 PM
