Pitted Crank Shaft 1997 Disco
Old Nov 20, 2013 | 09:41 AM
mhunterfm's Avatar
5th Gear
Default Pitted Crank Shaft 1997 Disco
i have a little oil leaking around the crank shaft seal, only when it's cold, and my mechanic mentioned that when he changed it a couple of years ago, he noticed pitting in the shaft. i'd like to avoid a tear down to replace the crank shaft so is there any way to cure the pitting? obviously if i emery cloth it down, the leak will most likely get worse.
anyone ever encounter this before and what did you do if anything?
besides ignore it and live with a little leak.....
Matt
Old Nov 20, 2013 | 11:16 AM
fishEH's Avatar
Matt
There's a few things you can do.
- Clean the area and smear RTV around the crank/seal. let it cure and it will kinda form a new seal to help stop/slow the leak.
- Replace the seal and recess it more/less so it sits on a better/letter pitted/not grooved part.
- Sleeve the crank
- Have the crank machined and polished.
I replaced the seal and recessed it more/less to ride on a better part of the crank. It doesn't leak any more, or at least not enough for me to care/notice.
See my thread on Dweb.
Crank Pulley / Harmonic Balancer resurface or Speedy Sleeve - DiscoWeb Message Boards
Old Nov 20, 2013 | 07:23 PM
jafir's Avatar
Are you talking about the rear seal or the front seal? Because I thought the front seal rides on the pulley instead of the crank.
kleener
Jul 12, 2013 08:06 AM
Irish Rovers
Dec 7, 2012 03:12 PM
QuinnBrewer
May 18, 2011 11:04 AM
johnkbl
Dec 29, 2008 06:12 PM
retrac
Sep 12, 2008 03:52 AM
