Please help my 98 disco is about to have a terrible accident lol.
Old Sep 14, 2014 | 03:17 PM
  #51
ihscouts's Avatar
Cool, sounds like some fun finally......
Some of us here used to be on LRO but when things went downhill we headed out to all points on the LR map. The short and simple on replacing an ECU is to buy the 10AS unit paired with it. Paul Grant is very familiar with this and you can find him here.
Old Sep 14, 2014 | 06:46 PM
  #52
snydesh's Avatar
I tried but the guy said the vehicle was gone (junkyard), so I am screwed.
Old Sep 14, 2014 | 07:24 PM
  #53
ihscouts's Avatar
No your not. Did you contact Paul Grant? If he doesn't have a pair then try Will Tillery or Drillbit. One of them will snag a 98 ECU/10AS duo and then all you have to do is take ten minutes to install them, reconnect battery and off you go.
Old Dec 19, 2014 | 09:57 PM
  #54
snydesh's Avatar
FYI problem solved. It had a broke reluctor tooth. Welded one on and now it is good to go, no more miss fire. I do have a high idle issue that started when I changed computors.....
Old Dec 20, 2014 | 06:44 AM
  #55
TOM R's Avatar
Need ecm values reset
What reluctor are you talking bout? Pics?
Btw you are much better here then the other board you posted a link to, people here actually work on stuff and are willing to offer help/advice
Old Dec 20, 2014 | 07:44 AM
  #56
snydesh's Avatar
Land Rover Discovery II 2 Flywheel 99 00 01 02 03 04 1999 2004 | eBay
Not sure how to post a pic, but here is a link to show you. Do I have to go to a dealer to get the values reset? I have read that before but it doesn't seem right to me. Everytime a sensor is replaced you have to reset the ECM??
Old Dec 20, 2014 | 01:11 PM
  #57
TOM R's Avatar
Oh OK I see, the crank sensor pickup
Yes, ecm reset to reset idle , resets value in IACV
Reset adaptive values, find an Indy rover shop, takes 5 minutes should be cheap
Thomas Lane
Feb 24, 2015 09:26 PM
Hyakku
Apr 5, 2011 08:21 AM
leeharrell
Feb 23, 2008 11:01 AM
DiscoII99
Feb 7, 2007 12:22 AM
