PO442 EVAP code..advice needed.
1998 D1. Went to inspection station and had this code show up. Original gas cap was cracked in two spots so I went and bought a new one. Went back with new cap, cap passed pressure test but code still showed up. No check engine light. Drives perfectly fine.
Thoughts? Hose issue? I did a search and found only a few threads here. Thanks
Thanks Walt. I'll start with the valve and see if that works.
The link you listed..does this particular one fit even though it says not compatible with the vehicle? I know sometimes parts fit because they are quirky British vehicles. Verifying before I place an order. Thanks again/.
