PO442 EVAP code..advice needed.
Old Aug 3, 2019 | 03:53 PM
stillruns's Avatar
Default PO442 EVAP code..advice needed.
1998 D1. Went to inspection station and had this code show up. Original gas cap was cracked in two spots so I went and bought a new one. Went back with new cap, cap passed pressure test but code still showed up. No check engine light. Drives perfectly fine.
Thoughts? Hose issue? I did a search and found only a few threads here. Thanks
Old Aug 5, 2019 | 07:10 AM
WaltNYC's Avatar
If you download the gems_obs.pdf in my link it looks as though the system believes it is not able to pressure test the purge valve due to a small leak. Could be a vacuum line, a PCV line, or the purge valve itself.
The valve is not expensive.. .
Amazon Amazon
Old Aug 6, 2019 | 07:26 PM
stillruns's Avatar
Thanks Walt. I'll start with the valve and see if that works.
The link you listed..does this particular one fit even though it says not compatible with the vehicle? I know sometimes parts fit because they are quirky British vehicles. Verifying before I place an order. Thanks again/.
https://www.amazon.com/dp/B003SOJV3C/?coliid=I335LBMFM5DAE0&colid=3SZYBJV1LFLYW&psc=1&ref_=lv_ov_lig_dp_it https://www.amazon.com/dp/B003SOJV3C/?coliid=I335LBMFM5DAE0&colid=3SZYBJV1LFLYW&psc=1&ref_=lv_ov_lig_dp_it
Old Aug 7, 2019 | 05:55 AM
aemnky606's Avatar
Yes it will I have the exact part in my truck. You will not need the adaptor that it comes with.
Old Aug 7, 2019 | 07:16 AM
WaltNYC's Avatar
Best4x4 suggests buying the original, not the Dorman. so here is the original if you like....
Amazon Amazon
Old Aug 7, 2019 | 08:30 AM
stillruns's Avatar
10-4 guys. Thanks for the help.
Antmen
Jan 11, 2020 06:52 PM
RANDY04D2
May 30, 2014 12:53 PM
Rover Chris
Feb 13, 2011 09:45 PM
dgilaon4
Jul 22, 2009 04:33 PM
Camdisco24
Aug 18, 2008 08:27 PM
