Poly Or Rubber bushings ??????
Old 07-16-2014, 12:29 PM
Richard Moss's Avatar
I have red "Prothane" bushes all round on my "other make" 4x4 and whilst they are supposedly harsher than the standard bushes, they are a damned sight better than worn out rubber bushes. No regrets
Old 07-16-2014, 08:56 PM
geek_IM's Avatar
I put the reds in mine. The ride is taut, but that is the way I want it. It also may be due to the fact the I am running BFG AT-KOs at 75 psi.
Be careful with the harbor freight press, I bought one and used it to do the job but also bore bruises for three weeks afterwards. That thing loads up like a compound bow, you should be very careful if that is the route you are going to take. I took an impact socket to the chest and man I'm telling you that really hurt.
As far as grease goes, I put handfuls of never seize on the bushings because I was worried that they were going to squeak. Eight months later bushings are good and nary a squeak to be heard.
Best of luck with whatever you decide to put in.
Old 07-17-2014, 07:47 AM
TOM R's Avatar
I used my 20 ton hf press, older model, you also need the ball joint master adapter kit they sell, we had no injuriesbut a few did take the full force then popped
MarkSF
03-17-2014 12:38 AM
ICECREAMEATER
06-11-2012 11:50 PM
ColoDisco
03-09-2012 09:31 AM
Chrisinhouston
12-31-2008 04:31 PM
TBW
10-10-2007 08:27 AM
Quick Reply: Poly Or Rubber bushings ??????
