Possible diff noise
Old Apr 25, 2011 | 06:00 PM
jasonrusso's Avatar
Default Possible diff noise
I have a loud whining/howling noise on the highway. It starts at 70, is loudest at 75, and almost goes away over 80. It goes away if I let off the gas. Is this possibly the front diff?
Old Apr 25, 2011 | 06:01 PM
Danny Lee 97 Disco's Avatar
Do not drive it over 65.
Change all your diff fluids ASAP.
Old Apr 25, 2011 | 06:03 PM
jasonrusso's Avatar
I already did. All the fluids were pretty black.
Old Apr 25, 2011 | 06:14 PM
dID YOU GO WITH THE HEAVIER WEIGHT?
Old Apr 25, 2011 | 06:22 PM
jasonrusso's Avatar
75w-90, what is your suggestion?
Old Apr 25, 2011 | 07:38 PM
Long Haul's Avatar
Check your wheel bearings and swival ***** for grease also. And check the Ujoints for grease As far as gear oil that weight is fine.
Old Apr 25, 2011 | 07:40 PM
kenk's Avatar
Check you're t-case fluid too while at it(same oil as diff's).
Old Apr 25, 2011 | 07:43 PM
jasonrusso's Avatar
I changed all the driveline fluids. I am pretty sure it is coming from the front. It sounds like it is around the passenger side floor. I think I can hear it if I put the pass side window down, but I may be wrong about that. I just tightened up the wheel bearings and greased the u-joints. Is there any kind of additive/ special fluid I could try?
cornbreadj
Dec 27, 2014 07:50 PM
dusty1
Dec 7, 2014 01:57 PM
suprange
Feb 16, 2014 09:09 PM
ConradLeo
Jun 22, 2013 09:02 AM
Disco2Guy
Jun 20, 2008 10:13 PM
