power seat pin out diagram
Old Aug 26, 2010 | 01:42 PM
NiteTrain's Avatar
Default power seat pin out diagram
does anybody have a pin out diagram for the seat controls? Both of my tilt switches seem to be bad and I need to make the seat tilt back. I assume I can just jump out the pins if I can find out which ones I need to jump out.
Old Aug 26, 2010 | 06:07 PM
Rover Chris's Avatar
they are reverse polarity on the motors,if you unplug the harness from the back each pin is numbered, you then have to apply either power to one side of the motor and ground to the other (or the other way around depending on the way you want the motor to turn) you will have to determine which plug is which but they pretty much line up with the buttons so if you think about the bottom part control it will be the horizontal plug and the recline control will be the vertical plug, anyways drivers side is as follows: seat forward put jumpers between pins 2/3 and 4/1. for seat reverse 2/4 and 3/1. for front of seat raise 6/3 and 5/4. for front of seat lower 5/3 and 6/4.
for the other plug (raise/lower back and recline) I would have to look at because the schematic shows different pin out numbers, if you need a more detailed explanation for a specific movement of a specific seat let me know and I will try to help
Old Aug 26, 2010 | 07:04 PM
NiteTrain's Avatar
yeah I need to figure out which pins recline on the smaller plug..im sitting almost straight up..very uncomfortable
Old Aug 26, 2010 | 09:51 PM
this should be the plug that the wires come straight out of the end, and sits vertically on the switch. basically the two pins that attach to the recline motor are pins 1 and 2, and the pins that provide the power are 3 and 4 (these should be the 2 larger pins), so basically a jumper between pins 1 and 3 at the same time as 2 and 4 will cause the back of the seat to either move up or down (if it is the wrong direction switch them to 1 and 4 as well as 2 and 3) and if the front of the seat moves up or down then you have the wrong plug. I should point out that I am saying pins but in actuality the pins are on the switch and the plug only has holes where the pins go.
I hope this helps.
Old Aug 26, 2010 | 10:02 PM
after review pin 3 is empty, this would be a ground but the switch shares it from the larger plug. I would just use a larger jumper and run it to pin 4 on the big plug then connect the other end to pin 2 on the small plug and at the same time short a jumper between pin 4 and pin 1 on the small plug, this should recline the seat.
Old Aug 26, 2010 | 10:39 PM
NiteTrain's Avatar
chris, that worked! me and my lower back thank you
Old Aug 27, 2010 | 01:12 AM
I have taken my seat switch apart twice now (which I assured myself would not happen again after the first time) I am currently kicking ideas around to replace (or figure out a way to permanently repair) my non working switch, I was thinking about just building a switch plate with 4 - 2 position switches however to allow for reversing polarity I would need 2 relays per switch for a grand total of 16 (yes 16 if I did both sides) relays sitting between the 2 switches! so maybe just a how to with screws and glue on "how to permanently repair the switch" for starters, then if that fails, I will do a "how to make a less expensive replacement".
Old Sep 6, 2024 | 12:17 PM
Esjo's Avatar
5th Gear
Default Seat Remake
my self im trying to replace the switches with windows switches for each motor x4 ( For each side )
Old Sep 6, 2024 | 11:58 PM
JohnZo's Avatar
I was able to find Mercedes switches for less money, and they fit just like OEM with minor adjustments.
I heard some folks detach the mechanical cables from the motor and simply connect a drill to the cable they want to adjust, then leave it there.
Old Sep 8, 2024 | 03:49 PM
Esjo's Avatar
5th Gear
I was about to do the same but the charged me 20bucks for a switch and i did not get them just bought some at the store the worked very well 5buck x1
ZGphoto69
Sep 8, 2022 08:07 AM
ProfGriff
Feb 7, 2022 03:25 PM
Tomzsix
Aug 26, 2020 08:25 PM
merebel
Jun 20, 2020 06:27 PM
gbob
Apr 13, 2014 08:22 PM
