Power Steering
Old Feb 23, 2015 | 07:32 AM
Hercu's Avatar
Default Power Steering
Had a serious bumpy trip to Ponta Do Oara this weekend.
On the way the power steering pump starts "Whining" as if there is no P/S fluid.
I bought fluid and topped up maybe 10 ml and was actually overfilled.
But the whining persists.
Any Idea's.???????
Old Feb 26, 2015 | 09:42 AM
TOM R's Avatar
Pump shot , I am replacing mine today it has been whining for weeks
Old Feb 26, 2015 | 01:29 PM
philwarner's Avatar
Originally Posted by Hercu
Had a serious bumpy trip to Ponta Do Oara this weekend. On the way the power steering pump starts "Whining" as if there is no P/S fluid. I bought fluid and topped up maybe 10 ml and was actually overfilled. But the whining persists. Any Idea's.???????
My pump doesn't whine, but there is often no power steering help at idle speed when warm although it works OK when first started. I can get some power steering if I hold the brake and rev the engine a bit. Same answer? Bad pump and needing a chevy PS pump transplant?
Old Feb 26, 2015 | 01:46 PM
TOM R's Avatar
The one I just replaced that was locking up was whining bad first start up for weeks but it is also been super cold here, wife said steering been hard but I did not notice it
Old Feb 27, 2015 | 04:36 AM
Hercu's Avatar
Damm!!!!! I suspected but hoped for a cheaper solution.
Thanks again.
Please report on any difficulty's whilst replacing.
Will order new one today and hope to receive within the next 3 weeks.
Regards
Old Feb 27, 2015 | 06:38 AM
TOM R's Avatar
You can use a Chevy s10 pump they are around $50 just need to change the boss that holds the pulley ( press on off) and the hose to the resevoir
Old Mar 9, 2015 | 03:44 AM
Hercu's Avatar
Thanks again.
Regards
Hi Guys,
You will never believe this Story: I needed to travel to South Africa with the "whining steering pump". It is about a 600 km trip passing 3 borders, Mozambique-Swaziland- South Africa.
Business done and on my way back, as I entered a small town something seized with a frightening noise which brought the Disco to a abrupt stop.
First to mind: "The whining Steering pump"
Slacked the tensioner on the belt and found the pump pully turning but the alternator is totally stuck. (The shaft pointing about 45 Deg west) Front bearing disintegrated.
Bought a universal V-belted alternator ($75) and changed the pully's on the road, fit the alternator and re-tension the belt.
AND: No more whining !!!!!! none, zero, nothing.
and yes, I have already ordered the new steering pump !!!
Old Mar 9, 2015 | 07:48 AM
TOM R's Avatar
Pumps easy to change just be sure to break loose the pulley bolts before removing the belt, probly like a 20 minute job to swap it
johnnyjohnny
Sep 26, 2019 09:37 PM
DiscoBritney
Dec 19, 2011 06:24 PM
orionpaxx
Nov 7, 2011 10:07 PM
losinov
Mar 21, 2011 08:57 PM
jycsalas
Apr 17, 2009 02:21 AM
