Power steering pump whine
Old Jun 11, 2019 | 09:06 PM
redrover75's Avatar
Default Power steering pump whine
I replaced my ps pump and bled the system. Now I have a whine tied to engine speed. Could it go away over time? Self bleeding? No bubbles in the reservoir, although I did initially.
Any ideas?
Thanks
Old Jun 12, 2019 | 09:09 PM
XCELLER8's Avatar
replaced with a new pump ? or used one ?.........and what did you use for fluid ...(.it should be ATF if you didnt know) ............the air and noise should bleed out after a few minute and some lock to lock turns
Old Jun 14, 2019 | 12:00 AM
OverRover's Avatar
If you didn't already do this, bleed any air from the PS Box.
" Now I have a whine tied to engine speed."
Any possibility you got some ATF on the belt/pulleys when the pump/hoses were removed?
Even a small amount can cause a whine/squeal sound.
Andy2Rover
Oct 15, 2024 05:35 PM
DadOfRoverOwner
Jan 16, 2021 07:32 PM
Greg Vasileff
Nov 5, 2017 10:47 AM
jayg
Jun 14, 2012 06:21 AM
casanova00
Jun 16, 2010 09:56 PM
